Old 28-09-2010, 05:14 PM
zakshaker zakshaker is offline
Default fiberglass tank
hello all,
I was wondering if any of you are using fiberglass tank ?
this could be designed to fit the car even better...
any downside ?
Old 17-10-2010, 09:18 AM
Default Re: fiberglass tank
anyone has any feedback ?
does methanol will behave with fiberglass ?
Old 17-10-2010, 01:56 PM
I wish I have knowledge on this.
I believe fabres are held together with some form of epoxy. Not sure how this compound reacts with methanol long term. Make you life easier, use a plastic tank with a known material.
Old 23-10-2010, 05:32 AM
Thanks,
I'm mounting a red petrol plastic tank (5litre) ATM
now about metals, I know aluminium is out of question, but is there any other metal that would cope with methanol ? stainless steel ?
Old 23-10-2010, 07:26 AM
Stainless 304, 316 will be good.
Old 23-10-2010, 04:48 PM
that's good news
I might design my own stainless tank later then
the tricky side will be the cap system
which foam could be used ?
Old 05-11-2010, 10:46 AM
thefalls thefalls is offline
Hows the in cabin noise of the pump?
I guess you hardly hear it as the exhaust muffles it.
Old 06-11-2010, 06:49 AM
as you said, I don't hear anything cause of the direct exhaust pipe.
I would guess with normal exhaust and back seat fitted, it shouldn't be very noticable. should be about the same as your fuel pump but lower frequency
