Old 03-01-2011, 11:43 AM
ricekikr ricekikr is offline
Default Pure Distilled Water
I understand the benefit of 50/50 at lower boost. But how come most people still run 50/50 when boosting 25+psi (I assume this is high boost)?
I have a 97 Audi 1.8t, currently boosting it 20psi stock block. I'm gona be building up the block in the next couple of months and plan on water or w/m injection and increasing boost to 25+ (probably around 30psi).
I'm really confused because most people use 50/50 and make power, never seen anyone use pure water, even though it costs less, should make more power, enables us to run shit loads of timing/boost and actually use less gasoline.
Questions:
1. So which will produce more HP? Pure water or 50w/50m or pure meth?
2. Why even use meth when pure water (from what I read) has a lot more benefit?
TIA
Old 03-01-2011, 10:02 PM
Default Re: Pure Distilled Water
Water injection and alcohol injection requires a different strategy to your tuning package and can be summarized as follows:
Inlet air cooling:
Both does the same job but under a different temperature range due to its freezing point and boiling point (-90C to +70C for methanol) and water between 0C to 100C. You need to inject twice amount of alcohol to one part of water. If you mix the two, you get a very wide operating temperature range and less amount injected in total. Recommended.
In-cylinder cooling:
Assuming you have already running an ideal a/f ratio of 12.5:1 (in general), neither liquid will be needed as extra fuel (alcohol). In this case, you need to consider water injection is better to control your peak combustion temperature spikes - latent heat is two times higher than alcohol. In order to have the same effect, you need a system that will flow twice as much with methanol and four times as much with isopropyl.
latent heat value by mass, injected quantity by volume (...):
Water ... 2256kJ/kg (1)
Methanol ... 1109kJ/kg (x2.53)
Ethanol ... 904kJ/kg (x3.10)
Isopropyl ... 665kJ/kg (x4.24)
(Gasoline) ... 350kJ/kg (x8)
From the above figures, you can see how much more alcohol is required to be onboard and the pumping system has to be capable of flowing much higher than just injecting water.
Octane value and knock resistance:
This is the stage of the comparison where water and alcohol injection parts company. Water does not have octane value or can be regarded as infinite since it will not ignite under the greatest pressure and temperature. Knock prevention works completely different to alcohol. Alcohol is octane rated so if alcohol is used a a fuel additive, so your fuel's octane is directly proportional to the amount of alcohol injected. I don't think I have the required knowledge to tabulate a comparison of the two concept.
My conclusion:
Water injection and alcohol injection is totally different when part of the alcohol is used as a fuel supplement and results should not be compared. It is like comparing a gasoline fuelled engine and alcohol fuelled engine
Old 03-01-2011, 10:55 PM
Questions:
TIA
It comes down to simple power production capability.
I have developed cars with both *water* and *WM50/50*
In short WM50/50 makes more power and is not as sensitive to low ignition power and allows you to use more conventional AFR settings most tuners are comforatble with.
Water works well, but on like settings makes less power (read my member rides thread for detailed discussion of different settings on my car and proof). To get water to perform at its highest levels you need to have a very high capaicty ignition in a high speed engine, and also you need to have much less fuel going through the engine, otherwise you will notice a power loss on fixed settings (like timing, boost, rpm etc).
This is well documented.
WM50/50 is the best I have found, it's window of tuning is more convential, and the power you make simply can't be ignored either, this is the main reason why I use it.
I have gone through this same situation many times repeated with a few drag racing customers who are running leaded VP Racing C16 fuel, and the results have been the same as I found testing in my own road car (which I used to verify their own feedback to me). WM50/50 will do the main job you want of improving the turbo efficiency, reduce the charge temperature, eliminate all knock in the engine, allow conventional settings of the engine managment (spark and fueling) + give you maximum power results which will translate to real world time improvments and higher velocities in whatever you are using the car for, road racing, drag racing, dyno sheet racing !
Hope this helps a bit?
http://www.aquamist.co.uk/vbulletin/...?t=1590&page=3 My own information and testing from page 3 inclusive, there is allot of information, but it all points to more power as what got me originally to test this myself after some prompting from my end users (after basically the same questioning as you have made)
p.s. In my own opinion I feel the mixture of the chemically combined WM50/50 lets the water do it's job and more of it is being utilized, in itsself the amount of M you are adding is trivial in the scheme of things on convential ratios of injection, it seems to me to make the water work (I.E. vaporize easier) the charge air temperature difference is where the extra density comes from (more air inhaled despite the injection of this additional fluid) and the cooler running is noticeable in all area's. When you hear a water injected car (water or WM50/50) running well nothing sounds like it! they have a certain note to them that is hard to describe, maybe its just eh sound of brute power? but you can hear and feel the power, they are unreal...... to get them to deliver perfectly, they do need fine calibration and indiviual tuning, once you find the sweet spot though you will know it and will never run your car without it. Tuning is the key to making it work perfectly.
http://www.riceracing.com.au
RICESP > F40 > Zonda > ZR1
Water Injection Specialist
Old 04-01-2011, 05:43 AM
Thanks for another great reply. Your posts are the main reason I think pure water is better or good enough (like in wrc)
So do you mean that if my current fuel/spark system allows me to run around 12.5a/r water will be more beneficial?
I've tried 12-12.5 before, but got a lot of timing pull, I now run 11.5 it has little less timing pull, . So in this scenario is pure water more benificiary?
In short WM50/50 makes more power and is not as sensitive to low ignition power and allows you to use more conventional AFR settings most tuners are comforatble with.[/i]
Thank you for replying.
Conventional being higher than 12 afr?
So basically even if I can ignite it and have higher than normal AFRs, w/m will still produce more HP vs pure water? Or would they have the same effect?
I ask because I've seen two 1.8t produce power (without meth or water) on 93pump on a 1.8t @ around 13afr. Not sure how much timing pull.
Dyno @ 13afr/93pump/25psi - Check the AFR
Thread:
http://forums.vwvortex.com/showthread.php?4065844
Old 04-01-2011, 06:04 AM
^ You really need to experiment yourself and see what works for you. On tests where you know all the factors invovled (and its not doctored one way or the other for a fixed result) in my samples (end users and myself) I found WM50/50 to be superior for power production *the end result more than justifies the hassel of making it*
I don't have enough time to theorise too much about it but I did go to the effort of documenting it with all associated settings and power production with vehicular performance and it's def better in my own finding.
Old 04-01-2011, 08:26 AM
Oh ok. Guess its really a case to case basis. Maybe that's why some people make more power with pure meth or 75meth. I just always leaning towards the tuning side why some make power some don't.
Anyways thanks for the info. Greatly appreciate it.
Gona try pure water and 50/50 and see which makes more power with my engine
Old 04-01-2011, 10:30 PM
keithmac keithmac is offline
I used 75M/25W, if you are injecting large amounts of liquid most ignition systems can`t cope with pure water (as has been said above).
For me the higher the quantity I injected the more Methanol I added to the mix (so technically the amount of water injected remained the same), I aimed for 10% to 15% water based on my main fuel injection and the rest was methanol, which also acted as a fuel (allowing the ignition to fire the mixture properly).
You can make great power and inject massive amounts of methanol without having spark blowout issues but it`s hard to tune without having a good system with a proper injector and controller (like the new Aquamist kits). Not really road car/ daily driver friendly at that level.
Old 05-01-2011, 05:24 PM
Pit Viper Pit Viper is offline
It's a pretty simple test for you. Use a vag-com to log your car, and do pulls with no water/meth, 100% water, and a 50/50 mix. See what's getting you the best results, and tweak it in from there. I've always gotten better results with a mix of water and methanol when I'm running pump gas.
Old 05-01-2011, 08:34 PM
Exactly what I'm gona do
I always keep forgetting the AEB has weak ass ignition. Might upgrade to ATW coils, if it can't ignite w/m or pure h2o.
Old 05-01-2011, 09:48 PM
I run a pretty heavy shot of water/meth on my A6 2.7 on the stock ignition. I haven't had any problems so far.
