Old 04-02-2011, 09:40 PM
calebtharrell calebtharrell is offline
Default HELP! HFS-5 not flowing past 806-244 Fast Acting Valve
I have had the HFS-5 system installed on my 04 STi for over two years and just recently it hasn't been working properly. I thought I had a clogged line or filter so I checked and cleaned everything from the pump to the sprayers. Everything was fine so I manually triggered the system and the Methanol makes it all the way to Fast Acting Valve then will not go any further. I am assuming the valve is triggered by the by the IDC. My guage will hardly ever show any flow but randomly sometimes it will flash one bar for a split second then stop. The conclusion that I have come to is that 1) The Fast Acting Valve is malfunctioning and needs to be replaced or 2) The system is not recognizing the IDC so the vavle isn't being opened. Does anyone have an idea that could help me figure out if it's one or the other or even possibly something else.
Old 05-02-2011, 04:49 AM
Howerton Engineering
Default Re: HELP! HFS-5 not flowing past 806-244 Fast Acting Valve
What version of HFS-5 do you have? How did you manually trigger the system?
Old 05-02-2011, 06:02 AM
I didn't know there were different versions. Im not sure. I wired power to the pump to make it cut on and I just realized that, that wouldnt be triggering the system. How do I figure out which version I have and how do I manually trigger the system. Sorry
Old 05-02-2011, 04:28 PM
The front of the control box will say V8, V9 or V10.
