Old 15-08-2011, 02:59 PM
bradman77 bradman77 is offline
Question HFS-6 flow controller wiring
Can someone correct me if I am wrong on the wiring:
Following items are in the Red Harness:
1 red 24awg +12V PSU to Flow control Module 1A max @12v
2 green 24awg Flow Sensor Calibration Signal 5-0 VDC @10mA
5 yellow 24awg Flow Sensor output signal 0-5 VDC @10mA
6 blue 24awg Reserved for internal communication usage Signal level digital
8 brown 24awg PWM valve distribution signal 1A @12V max.
Following items are in the stand alone cable:
3 pink 24awg Wastegate By-pass valve option (+12V) 1A max@12v
4 white 24awg Wastegate By-pass valve option (SW-) 1A max to Ground
Ground is the singel wire out of the module:
7 black 24awg 0V Ground (signal ground) 1A maximum
Thanks!
Old 16-08-2011, 12:14 PM
Default Re: HFS-6 flow controller wiring
bump, anyone?
Old 17-08-2011, 10:11 AM
- Pin1 and pin3 are joined at the FCM module. Your information is accurate.
- The blue wire (post 2010 Dec) is now used to read raw digital signal from the flow sensor. Per-2010 Dec is a return ground to power up the RJ45's green led.
