Old 20-10-2011, 10:58 PM
Johnny A Johnny A is offline
Default Newbie needs guidence
Hello people, I am a total newbie to WI and am looking for advise on a proposed addition of an Eaton M90 blower to my straight 6 3.0 24v Carlton estate.
Basic engine spec:
3.0 inline 6 twin cam 24v
10:1 CR ratio (this will remain unchanged)
Bore/stroke 95x69.8mm
Standard management
Intended fuel: 97RON 'super unleaded'
Eaton Gen3 M90 blower taken from a GM3800 engine from the states (internal bypass) 10psi target pressure to start with.
Aquamist MF2 to drive one high flow injector (3D mapped using MAP sensor)
Aquamist WI setup I bought S/H with pump, boost switch and a few injectors (unknown size)
AEM wideband lamda and gauge
I plan to run no intercooler or chargecooler up front, the blower will be mounted Mad Max style poking out the bonnet and blows down into the inlet tract.
I have done a bit of reading on the site and many people seem to favor a straight 50/50 mix on the WI, but due to running no intercooling maybe I should sway more towards running say 30meth/70water for more cooling??
What AFR's should I be looking at on boost? Does the WI replace all chamber cooling or only some? Would 13:1afr with WI be suitable or do I need to go richer??
Would it be a good idea to run a smaller WI jet before the blower to increase efficiency and then a larger one after to cool the charge?
I do realise the system will depend heavily on WI to prevent the engine from melting/blowing up so I do intend to install several safeguards should the WI system fail or run low.
Any help and additional suggestions would be appreciated
Vauxhall Carlton Estate 3.0 24v S6
Vauxhall Carlton Lotus replica 2.0 16v Turbo
Old 20-10-2011, 10:59 PM
Default Re: Newbie needs to guidence
oh dear I got the title a little wrong, makes me look like I am semi-literate lol
Old 20-10-2011, 11:16 PM
Default Re: Newbie needs guidence
corrected?
Old 21-10-2011, 04:14 PM
yes, thank you
