Go Back   waterinjection.info > Aquamist specific system Q and A and new products > Aquamist systems in details and latest offerings
Old 15-09-2012, 09:38 AM
Default NEW product... checkvalve jets
In order to minimise the dribbling effect immediately after the spray-off period, especially in jet location where there are pressure differences. We have introduce the full range of CVJ (check valve jets) for "direct port", multiple jets such as post IC, pre-IC and pre-turbo.
There is a 1-bar check-valve capsule inside the jet, the assemble is fully serviceable by end user. it is now available.
It is now possible to use multiple jets to any location from one distributing manifold block (see 2nd picture below) without the worry of water inside the lengthy hose being emptied after system stops spraying.
****** Associated components *******
Old 15-09-2012, 07:47 PM
Default Re: NEW product... checkvalve jets
Some nice stuff there !
Old 16-09-2012, 04:03 PM
We are planning to life easier for those who wants to run multiple jets.
Old 05-12-2012, 05:31 AM
Dust Dust is offline
You mentioned before that you were looking at going up to 1/4 NPT for the nozzles, did this never happen?
Old 05-12-2012, 07:32 AM
Yes, we have them... with internal filter and checkvalve.
Old 27-06-2013, 08:36 PM
JumpingJackson JumpingJackson is offline
Richard, i have some of those new nozzles, with them you included some sort little bronze swirly pieces that look like they go inside the nozzle What are these for?
Old 30-06-2013, 08:50 PM
The little swirly parts are for other flow rates in case the CV jets flow too much. They are part of the jet internals.
Old 12-07-2013, 10:01 PM
Wolf_Tm250 Wolf_Tm250 is offline
Are these M8?
Can't find it anywhere.
Wolf_Tm250 [Silat-Kali lover]
TM enduro 250cc 2stroke
Toyota Celica Gt-Four ST205 Snowy White[2.34kg/hp]
Old 14-07-2013, 04:52 AM
Howerton Engineering
Yes, they are the same as the standard jet, except about 7-8mm longer.
Old 14-07-2013, 09:01 AM
Thank you.
Are they worth it in case of a dual jet setup spraying both post IC, or just in case of a pressure differential?
