Anyone had any experience with a renault clio.
the aquamist is plumbed in and has been for sometime now, just having problems with the wiring, namely 1. 4-way Power-in connector: - Red ................ Switched 12V (IGN SW#2) - Black ............... Chassis ground - White .............. Chassis ground Purple .............. Head lamp switch (optional) 2. Signal to the yellow RJ45 connector: - Red ................. Ignition switched 12V - Green ............. Fuel injector (-) pin - Blue ..................MAP sensor (optional any help/suggested would appreciated peter |
