Old 23-03-2013, 05:01 AM
dave80 dave80 is offline
Default VW MK5 HFS-4 DPI install.
I did some work today and almost finished the aquamist install. Made two brackets for the distribution manifold port that bolted up to the noise pipe bracket on the alternator:
but ended up using this one
fav mounted on the engine mount (plastic bracket used to hold the noise pipe)
Now I just have to splice some ecu wires and make the final electrical connections and I'm ready to go.
Old 24-03-2013, 10:20 AM
Default Re: VW MK5 HFS-4 DPI install.
Looking great. Nice install.
What are the sizes of those checkvakve jets?
Old 24-03-2013, 11:07 PM
jets are 0.3mm
Old 25-03-2013, 01:04 AM
It looked like 0.7mm!!!
What power is this engine capable of?
Old 25-03-2013, 03:43 AM
currently i'm running apr's K04 turbo and tune, but that's a mild safe upgrade for a daily driven car.
Old 13-04-2013, 08:43 AM
Final install pics of my aquamist kit.
2 gallon Tank. It's also mounted to the floor and can be easily moved to access spare tire if needed. Fold the seat and just have to push the tank in.
Outlet of the intercooler drilled and tapped. Second pic shows the jet installed.
Ecu wires. I stripped the old tape more than enough, but gave me lots of room to tap the wires properly.
Once I confirmed all the connections were leak free I installed some protective sleeves over the lines.
Have some pics showing how I routed the main feed line from the trunk to the engine bay using the fuel line route, but will upload them later.
Old 14-04-2013, 03:52 PM
Howerton Engineering
Very nice install. It's always good to see the final results of where all this stuff goes!
