Old 27-04-2013, 04:18 PM
gakzilla gakzilla is offline
Post HFS-6 leak found, about to fix, have questions on full cycle priming
Newbie here, searched high and low, found a couple threads that answered some questions but I have some additional ones at the bottom. Any help is appreciated.
Bought an 01 Audi S4 with hfs-6 installed on it running 100% meth. Developed a leak some time later, found the problem to be a faulty push-fit elbow fitting. Got all the new parts from howerton, everything seems straight forward.
Questions are:
1) Once everything is put back together, I know I need to prime the pump and clear the lines of air using manual trigger/test mode. By doing the test mode, will it throw off any settings that the prior installer set on the hfs-6 system?
2) After all the lines are cleared and reinstalled, is there anything else left that I need to check on?
Thank you!
Old 02-05-2013, 11:00 AM
Default Re: HFS-6 leak found, about to fix, have questions on full cycle priming
Answers:
1. The settings will not be affected unless you tuned your car with a leaky system.
2. I suggest get it a quick tune in case the system is pumping more fluid into your engine.
