Old 01-02-2014, 12:01 PM
sniper sniper is offline
Default Datalogging HFS3v3
Hello forum.
I have a question regarding HFS-3
How can i get data log of 0 to 5 Volt?
FIA2 Aquamist has a purple wire with voltage signal 0-100%
Second question:
Can i get 30 pin scheme (each pin purpose)
Are there any useful pins for data logging and data graph (i marked these pins with green on the photo)?
Old 01-02-2014, 04:49 PM
Default Re: Datalogging HFS3v3
Here are some useful pins for data logging:
#5 ........... System start-up: 12V = system on.
#6 ........... Flow sensor signal: 0.5 to 4.5V
#7 ........... Water level sensor: 0v= empty, 5v= not empty
#8 ........... Fuel injector (-). not direct injection.
#16 ......... IDC% signal: 0 to 5V
#17 ......... MPS signal: 0 to 5V (signal conditioned)
#18 ......... IDC% to the water injection valve
#23 ......... System power: 12V (switched/fused)
Old 01-02-2014, 10:15 PM
Thank you very much!
You could describe these pins in manual, so that would bring more customers
Old 01-02-2014, 10:25 PM
Those pins are not static-protected so I rather use them as intended for remote diagnostic usage. They exist for the benefit for us and customer without working knowledge of our system but equipped with a simple $10 digital voltmeter.
It has been extremely useful since it was introduced.
For more knowledgeable users, all they need to do is ask here.
Old 04-02-2014, 06:56 AM
Richard L at 402 meters there is no time to consider devices.
Everything that happens with the engine we look at dataloge after racing.
Old 04-02-2014, 01:44 PM
What car is it? A 10s/quarter one?
Old 04-02-2014, 05:17 PM
Yes
http://www.youtube.com/watch?v=Z3FhekxHuXw
I include datalog
Old 04-02-2014, 06:41 PM
Wow, very impressive! How much power?
I can seem to see the data datalog. It will be quite interesting.
Old 05-02-2014, 07:57 AM
Richard AUXFS control only HFS4?
HFS3 do not have it?
344 wheel N/A
Old 09-02-2014, 09:11 PM
Interesting 11s log. Are you able to log the water flow now?
Only HFS4 has AUXFS.
