Old 13-08-2014, 05:04 PM
andysharp andysharp is offline
Default Water Level Sensor Issue?
Hi Richard
got the HFS-4 system on my Peugeot 207 gti and its been running superb since install last June. No settings or adjustment have been tinkered with.
Yesterday when was out, was accelerating got to the level where it normally injects and was no flow showing.
what was showing was the B in red for a milli second followed by the WINJECTION and WATER LEVEL yellow lights that stayed on solid till I came off the gas, and no flow showing.
The red S for flow sensor shows all the time.
When the water level comes on solid, am I correct in saying it will not let the system inject yes?
Today before I went out, I filled up the tank though was plenty in tank and again the same happened.
Took all the connectors out the back of the circuit board and reconnected them, when you do the manual test and activate the pump, you can hear it but the yellow lights on WINJECTION and WATER LEVEL come on solid again.
Its running off the injector pulses and the F-IDC LED panel flickers away as its picking the signals up from there.
Water level sensor at fault here perhaps?
Andy
