I decided to build a temporary pressure gauge to more accurately set my pump pressure after I originally tested my setup with different pump pressures. I'm interested in learning what the specific pump pressure should be after the affect of check valve jets and maximum boost pressure at wide open throttle. I've been told to leave the pump pressure alone (leave at 165psi) but after check valve jets and high boost levels I want to know if it needs to be adjusted. Should it always be 165psi at the pump while check valves and boost decrease this pressure or are we aiming for 165psi at the nozzle after check valve jets and boost? This will help me more accurately set the failsafes since I've already determined how to adjust the board trimmers properly.
Setup: HFS-4 system Four .4mm direct port injection check valve jets One .6mm post intercooler check valve jet Pressures: Pump pressure = TBD Single check valve jet cracking pressure = 15psi Maximum boost pressure in upper engine rpms = 25-28psi Calculating My Setup: I plan on flow testing all of the nozzles for a more accurate measurement but first I wanted to look at the online Aquamist Pressure vs. Flow chart and see where I landed. I calculated my methanol content, OEM fuel injector flow rate and each check valve jet. ![]() Pressure Gauge: This is a simple pressure gauge with a 6mm push fit connector on one end and a 4mm push fit connector on the other end. I disconnected the 6mm line from the FAV inlet and inserted it in the 6mm push fit connector on the gauge. On the 4mm push fit connector end of the gauge I ran a short 4mm line with a .6mm check valve jet spraying into a laundry detergent bottle. This pressure testing bypasses the FAV (I still removed the FAV jumper on the HFS-4 board to be safe) and only has to overcome the 15psi cracking pressure of the one check valve jet. ![]() ![]() ![]() Notes: -I reset the pump pressure as per the Aquamist instructions; turn the tiny allen screw clockwise until it clicks then turn it counter clockwise one full rotation to set the pump to 165psi. -When I first put the jumper on SYS to turn the pump on I noticed the pressure gauge bounced around 150psi. I'm assuming this is the 165psi less the 15psi cracking pressure of the check valve jet. Add in max boost levels of ~25psi and the pressure would drop to 125psi. -When I turned the tiny allen screw counter clockwise one more full rotation and jumped the board, I noticed the pressure gauge bounced around 120-130psi. -When I turned the tiny allen screw clockwise two full rotations until it clicked again and jumped the board, I noticed the pressure gauge bounced around 180-185psi. QUESTIONS: -Turning the tiny allen screw clockwise increases pump pressure? -If so, then turning the tiny allen screw clockwise where it clicks is the highest pump pressure? -Should my pressure gauge shows 185 psi (tiny allen key screw turned fully clockwise until it clicked) so my nozzle pressure is at 145psi (185 pump - 15 cracking pressure - 25 max boost)? -If my pressure gauge shows 165 psi then are my flow calculations on the above Aquamist Pressure vs. Flow chart (red vertical line at 120psi) correct and is this what I should be running at even though I still show a slight amount of timing correction in the upper rpm range where I could use a little more flow? Last edited by HYDE16; 06-09-2014 at 06:17 PM. |
