Old 15-12-2014, 08:23 PM
parmas parmas is offline
Default Spark Plug Heat Range
Discussing Spark plug Heatrange on boost.
Engine in the example is a:
- Toyota Yaris 1.5L
- Normally aspirated engine
- Stock 10.5 : 1 Compression / Turbo 8.5 : 1 Compression
- Stock Plugs BKR5EYA 0.8mm gap
- Street Use
Normally when going from N/A to F/I many use 2 steps colder plugs or more according turbo and engine compression. Is it the same case when using water injection ? Water Only for now.
Let's say I did go 2 steps colder on the 8.5 compression. Would this result in poorer engine efficiency while idle and cruising than using stock plugs?
I think answer is obviously yes!
Would water injection reduce spark plug heat range in a way to make it work cooler during combustion?
I think the answer is yes if using same fuel and ignition settings.
So why would a person switch from N/A to F/I go to colder plugs if he is not running lots of boost ? (above 20psi ? )
I tried it and eventually didn't blow the engine but instead got the engine efficient by leaving stock plugs and inject water immediately on boost.
What are your thoughts about this ?
Old 17-12-2014, 01:22 AM
Default Re: Spark Plug Heat Range
The spark plug does not directly control the efficiency of the engine unless you have such a cold spark plug that it fouls itself with carbon deposit leading to misfires.
If you inject water in the right proportion (around 15% to fuel in boost) you would normally not need to use a 1 step colder than stock plug. At the current power level you run, I would use a BKR6EYA.
Old 17-12-2014, 08:54 PM
Thank you for your suggestion.
I am running BKR6EYA of at right now.
