Old 03-05-2015, 03:48 AM
johnmx3ze johnmx3ze is offline
Default hfs-6 in 09 wrx problems
hi guys, first post in here...
i just installed a new hfs-6 kit on my built 09 wrx, im pretty sure everything is hooked up right but heres my problem...
1st i put water in the tank until level sensor was fully up then i turned key to on position and the yellow led light up for 10 secs and then turned off and no other leds lighted up... all lights on control box were green, then i tryed testing the pump with the prk jumper on the test link and turned key on and the pump started after 10 secs and water came out of the hose so then i turned it off and put jumper back on prk... but now everytime i put the key to the on position it sprays :/
not sure what im doing wrong so any help would be appreciated
if someone could walk me through the first test to do, thanks
Old 17-05-2015, 05:44 PM
Default Re: hfs-6 in 09 wrx problems
Remove the green wire of the yellow harness from the fuel injector(-), tell me what happen.
