Old 19-05-2016, 01:40 PM
porterhouse07 porterhouse07 is offline
Default HFS4v3 on 2013 Mazdaspeed3
I have a HFS4 kit about to be installed on my genpu soon. I've seen the wiring diagram for the HFS4v2 kit. Is it the same for the v3 kit?
Also, at the bottom of the diagram it shows what do at the solder locations. I should change the setting for the MAP sensor because I have a 3bar MAP, correct?
Is that all that I need to change and I'll be good to go?
2013 MS3 Black Mica
GT3071R | HTP 3" Intake | Magnaflow CBE | Grimmspeed EBCS | Bosch 3 Bar MAP | AP v3
CS HPFP Internals | CS Catted DP | CS RMM | TR8L FMIC w/ JBR Piping
HKS SSQV4 BPV | CS SSP | Swift Springs | DM Stage 3 OCC and PCV Plate | EBC Slotted Rotors w/ Yellowstuff Pads | NGK Iridium -1
Freektuned 350/365 @22psi
Waiting to install.... TR8L Core/Aquamist HFS4/NGK -1 Plugs
