Old 21-07-2016, 02:09 PM
Lolo La Torche Lolo La Torche is offline
Default Checkvalves
I have a "standard" HFS3 kit that I bought in 2014. So equiped with standard jets (no cheks valves).
I use 2 jets, 1mm and 0.9mm. 100% meth. PreThrottle injection.
I red several time on the forum that it's far better to have 1 checkvalve by extra jet. I still have the jets (supplied in the kit), what checkvalve could I use? Where can I find some?
Thanks!
Laurent
Old 21-07-2016, 05:32 PM
Default Re: Checkvalves
Unless the hose between the jets is longer than 2 feet, it may not be necessary.
Why putting a jet at the throttle?
Old 22-07-2016, 10:29 AM
Not at the trottle but just after the atmostpheric BOV (30cm from the throttle) in order to avoid meth vapors in the engine bay (It will be a 100% meth use)
Old 22-07-2016, 06:59 PM
Regardless of where the jets is in the charge pipe, meth will get blown out in any case.
Old 23-07-2016, 09:33 AM
Ok!
thanks
