Old 24-09-2016, 02:54 PM
Paulekas Paulekas is offline
Default Need help with my system
Hi guys i have older version system from 2010 and trying to figure it out how to use it basically when i try to adjust SC buttom clockwise or counterclock wise on ignition on flow gauge display doesnt light up but i know it changes when i drive and boost kicks in is there special screwdriver i have to use or gauge is messed up? Also would like to perform manual spray test to see how it sprays can you pls tell me how to simply do that thx so much
Old 24-09-2016, 03:10 PM
Default Re: Need help with my system
Also even if it works there are 20 clicks on SC buttom how to know how many cc per min every click gives since at about half turn flow gauges shows full flow plus its in ml per minutes
Old 24-09-2016, 08:43 PM
You really need to read the user manual again. It is too much to cover on few posts. Sorry.
Old 25-09-2016, 12:35 AM
Hi richard i pretty much figure it out except one thing when i set to CAL mode and try to adjust gauge SC for flow seems like clockwise give less flow and if i drive and adjust clockwise gives more flow also how to know approximately how many cc/m each click is ? And which direction to to SC to get more or less flow?
