Old 26-09-2016, 04:29 PM
turbonutter turbonutter is offline
Default FAV Voltage
I am using an Aquamist FAV to control the WI on my system, controlled by my engine ECU. I am currently wiring it up & was about to connect it to +12V, but noticed the coil is marked 6V DC.
What would be the best way to connect it to +12V and use a maximum of 50% duty from the ECU output (Low Side PWM) or I can connect to a +5V supply & use the full 100% signal, but then I guess the valve will only open 80% maximum?
Neil
Old 26-09-2016, 10:37 PM
Default Re: FAV Voltage
6V is for steady DC on/off operation.
12V with a PWM signal is ideal.
Old 26-09-2016, 11:11 PM
Thats Great - Thanks for the info..
Old 27-09-2016, 10:24 AM
I forgot to ask, is there any specific PWM frequency that works best?
Neil
Old 27-09-2016, 05:18 PM
25-35Hz is ideal
