Old 24-05-2017, 07:03 PM
rxheaven rxheaven is offline
Default Mazda RX7 FD3S Series 8 Setup
Hi Guys,
Does anybody have a wiring diagram for a series 8 rx7. I have seen diagrams for the earlier 8 bit ecus but not the 16 bit. Also what should be the setting for on-board trimmers and advanced system configurations.
My engine spec is: stock port 13B-REW, GT35R Single Turbo, 1680cc secondary injectors, 550cc primary injectors, OEM map sensor and apexi pfc ecu.
I plan to run preturbo and .6 at the boost elbow.
Thanks.
Old 26-05-2017, 07:53 AM
Default Re: Mazda RX7 FD3S Series 8 Setup
I found this might be the right one?
Old 26-05-2017, 03:32 PM
thats the one. Do you have the pins for the last right connector?
Old 26-05-2017, 05:58 PM
Re-pasted. Sorry. see above
Old 26-05-2017, 07:57 PM
Great. So using the 8bit diagram. Would this be the correct wires?
Old 26-05-2017, 08:28 PM
All wires must go to the appropriate pins on the 16-bit ECU.
Tags
fd3s, rx7
