Old 31-07-2017, 05:48 PM
George@Soho George@Soho is offline
Default HSF-3 VW Jetta GLI Install Problem
Hello, I'm having an issue with this system. Everyting is wired correctly and I am getting powers and grounds where I need them, but as soon as I turn the key on the system starts spraying. Any ideas? This is my 8th aquamist system install and the first one I'm having problems on, thanks.
Old 09-08-2017, 08:41 AM
Default Re: HSF-3 VW Jetta GLI Install Problem
Cost the wiring diagram you used.
Wiring may be correct but the wiring diagram may be wrong.
Old 10-08-2017, 01:22 PM
The car is not direct injected but has aftermarket 1300cc injectors. Used the DI harness and everything worked as normal.
