Old 22-02-2018, 08:20 AM
Rashid_Seyadi Rashid_Seyadi is offline
Default BMW S55 Controller Issue
I have purchased methanol kit a year ago for my BMW M3 F80 (S55 engine) i got the HFS4 V3.1 controller installation is perfect and the kit worked well, till today i changed my car's setup which required more meth to be sprayed so i changed the setup in both the gauge and controller, i had 2 choices either to get more meth sprayed or make it spray earlier i tried both ways and failed to get the required capacity of meth. So i decided to use my friend's controller installed on his Golf R MK6 the controller's settings were on default, i ran the car and meth was working perfectly as i wanted it sprayed enough meth. I compared both controllers and found no differences between them from both sides and versions except for the rectangular piece on the front face of the controller.
Going to my question i just want to know if i can buy the same controller for my car and will it be applicable and safe to use?
Thanks.
File Type: jpg Golf R MK6.jpg (157 Bytes, 22 views)
File Type: jpg BMW S55.jpg (157 Bytes, 21 views)
