Old 25-02-2005, 05:56 AM
white90 white90 is offline
Default no water went faster and with detonation?
i went to the track tonight, made a run and had some detonation, I pulled some timing and detonation was gone, i ran lean on a run, so i upped my rear jets. i make a significant jump, 88s to 94s. Well i ran it checked a plug and it was good, ran again with the water off and checked the plug and no detonation, it ran faster without the water and with out knock. What should i do now, l have the timing down perfect but i still want to run the alky. im running 24* timing on a 383 supercharged 142 blower and a holley 750. should i bump the timing to 26 or 28 and run the alky. how much hp would that offer. thanks guys
383 chevy, 12 lbs of boost, wieand 142 blower, alky injection
Old 26-02-2005, 03:49 AM
Default small steps
Just make small changes and see what happens.
Repeat the same sort of small changes and checks and learn what your setup likes.
No one has a broad enough experience base on your engine to diagnose your next step better than you can. You obviously under stand the basic elements of testing and then making an adjustment, then seeing what happens.
As a general rule WI is most useful when you reach knock limited performance levels. You now know about where your setup crosses that threshold. For most setups, you would then dial in settings of fuel/air and timing that are just a bit over the edge but turn on the WI.
If you now have no knock, then you need to find your best timing for the WI. In your shoes I would probably add a bit of timing in small steps.
You don't want to run more timing than necessary to get about 99% of max power. Beyond that point cylinder pressures (loads on bearings) and such go ballistic with very small additional changes. In studies on WWII combat aircraft studies they found the timing that produced max power than pulled back the timing until they saw a 1% power loss --- this is what they considered MBT (Minimum best torque) timing.
If you see no significant change in power as you add timing you have probabably gone too far and need to back up in very small timing steps.
When you get to that point back off the timing just a bit, then start leaning things out.
After you have made noticable fuel changes you will probably want to re-check your timing is still near MBT. When you get to the point your seeing no increase or rapidly slowing improvements in power, as you lean things out, you are near the best fuel / air ratio.
At that point I'd add a bit more water/alcohol and then start the step wise process over.
Just a guess as I'm using my psychic powers here
Old 04-03-2005, 12:39 PM
dc96819 dc96819 is offline
I would up the timing
