Old 14-08-2005, 08:29 PM
t18con t18con is offline
Default newbie question
ive just installed a 1s aquamist setup on my 18t vw, however , under vacuum the system is weeping into the cylinders causing a misfire. what have i done wrong?
Old 14-08-2005, 10:14 PM
This is an easy one to solve.
You need to install an inline checkvalve 806-249.
Old 14-08-2005, 10:17 PM
so my install locations arent too high/low then?
Old 14-08-2005, 11:44 PM
The location is not the problem it is the location of the jet. If there is vacuum present, it will draw water through the pump.
Or
You can relocate the water jet in on the air filter side of the throttle.
