Old 15-10-2005, 12:27 AM
Rootzz06 Rootzz06 is offline
Default Soot Free brand alchohol/fuel
While shopping for methanol,I came across this stuff in a camping section of a marine supply store it has a mix of stuff even though it is advertised as denatured alchohol for alchohol burning stoves.I dont know the percentages.It contains acetone wich I think is some people experimented with as a gasoline additive. hope this is of interest to some of you. ethyl alchohol,methyl alchohol,acetone,methyl-etyl ketone.The label says it is water soluble and can be use as winshield washer antifreeze,general cleaner or a thinner.It was 3.75 for the gallon.I have been using it for a few days.
Old 15-10-2005, 02:25 AM
GotH2O GotH2O is offline
Denatured alcohol = ethanol + [methanol + fouling agents (acetone, MEK....)] to make it undrinkable. Stay away from it....all the ketones, mek, acetone....are powerful solvents, bad for seals and hoses.
Old 15-10-2005, 02:28 AM
Thanks for the advice--I'm just going to stick to methanol/water mix.
