Old 20-02-2018, 08:13 PM
tezlum tezlum is offline
Default Setting WL
Currently I'm trying to set up my HFS-3.0 and I was having issues with the failsafe coming on at right when the threshold is triggered I have my threshold set to 12% with a 1.0 and .9 jet. I have the WL all the way CCW and it still goes into failsafe is this an issue of the jets flowing to low at 12% to get within the range of the flow sensor? I have a 2009 WRX with ID1000cc and using ~70% of them. Is there any way to modify it to get the sensor to read lower values with still having ~800cc/min of water/meth and still have use of the WL fail safe I did see the forum below but it was disabling the WL Failsafe http://www.aquamist.co.uk/forum2/vbu...hp/t-2647.html
Thanks in advance for tips or advice
Old 21-02-2018, 09:32 AM
Default Re: Setting WL
Sounded like thereis a mismatch of the iDC signal. Set the the IDC pre-scales to x1.5.
Old 21-02-2018, 06:56 PM
After I solder the 1.5x scaler will all the aquamists setting now be based off the scaled injector values so if I set the threshold at 18 it would trigger when the Inj DC is at 12. Then can I use the gain to scale back the jets DC will it work if I have the gain at -25% the gain will be now 1:.75 vs the default gain of 1:1
Old 27-02-2018, 06:36 PM
Thanks Richard, With the 1.5x soldered and the gain at -25% I worked great and I was able to set up my WL properly now
