Trying to find the best location for my jet/jets
I have small intercooler with poor airflow due to mid engine layout, set up is as follows- IAT before turbo MAP sensor aftermarket ecu no MAF 50/50 water meth Large turbo and large injectors running 1.6bar boost Currently have jet after intercooler about 5 inches before throttle body, but have the option to move it a further 15 inches back directly at the exit of intercooler, would this be better or could I use two jets in both locations? |
If you can put it the exit of the IC, you will get the best cooling effect and cylinder distribution.
Richard, What if the mixture has to go through 4 bends before the throttle body. Would it still be as effective?
It would be better for mixing due to turbulence passing every bend.
