Old 01-05-2014, 05:29 PM
chris-mr2 chris-mr2 is offline
Default jet location mid engine car small intercooler
Trying to find the best location for my jet/jets
I have small intercooler with poor airflow due to mid engine layout, set up is as follows-
IAT before turbo
MAP sensor aftermarket ecu no MAF
50/50 water meth
Large turbo and large injectors running 1.6bar boost
Currently have jet after intercooler about 5 inches before throttle body, but have the option to move it a further 15 inches back directly at the exit of intercooler, would this be better or could I use two jets in both locations?
Old 01-05-2014, 10:20 PM
Default Re: jet location mid engine car small intercooler
If you can put it the exit of the IC, you will get the best cooling effect and cylinder distribution.
Old 02-05-2014, 01:00 AM
Richard, What if the mixture has to go through 4 bends before the throttle body. Would it still be as effective?
Old 12-05-2014, 07:49 AM
It would be better for mixing due to turbulence passing every bend.
